Posted at 16:55:48 Wed 6 Oct 2021
Loco & Decoder types.
In the main more locos are sold 'DCC Ready' than 'DCC Fitted' sometimes documented as 'DCC On-board'.
'DCC Ready' means that the loco is a DC Analogue loco which has a socket inside it that can be fitted with a DCC Decoder to make it DCC operable.
DCC Fitted or DCC On-board means that the manufacturer has fitted a decoder at the factory.
Decoders come in different types.
They can have 4 pins, 6 pins, 8 pins, 18 pins, 21 pins plus some other variants as well. At the current time, Hornby 'DCC Ready' locos are more likely to have 8 pin sockets, but be aware that small locos may have 4 or 6 pin sockets due to the need for less space to be used.
Bachmann, models are typically 21 Pin sockets, but again this can not be relied upon as an assumption for ALL models.
Then once the number of pins is identified, you can get basic decoders that just control the motor. Basic decoders with additional function outputs [controlling locomotive lighting for example which is more common on Diesel locomotives and unlikely on 'steam'.] Then there are decoders with functions AND SOUND.
One question that gets asked a lot, is.
If I have purchased a DCC Fitted loco but want to upgrade to sound, does the sound decoder get installed alongside the fitted decoder?
The answer to this question is NO. Sound decoders have a fully functional motor decoder circuit in them. Thus they REPLACE the fitted decoder to perform ALL the necessary control functionality AS WELL as producing the sounds.
The Select controller is very basic. It can not be used with any mobile phone APPS.
It has a very much reduced addressing capability 1 to 59 for locomotives and 61 to 99 for accessories such as points. So if you built a layout with more than 38 points, then the Select is unlikely to fit the bill.
Compatibility.
In principle all DCC equipment is [should] be compliant with the NMRA DCC Standards. This means that DCC equipment sourced from different manufacturers should in theory interoperate with one another. We do see the occasional issues posted on the forum regarding certain decoders, but in general these are rare. The main thing to be aware of is that not all kit implements the FULL range of features supported by the NMRA standard, and some manufacturers implement their own custom extensions to the products, but basic functionality should be consistently supported across the products. For example the reduced addressing range that was stated for the Select above. The FULL addressing range written into the NMRA standard is 1 to 9999 for locos and 1 to 2048 for accessories.
Further Reading.
You may benefit from reading my downloadable 'Getting Started' PDF. Chapter 5 describes DC Analogue control and Chapter 6 describes DCC Digital control. My PDF can be downloaded from the sticky thread located at the top of the 'General Discussion' forum index.
EDIT. Rob posted whilst I was still typing, therefore much of his post is duplicated in my own.
THIS IS A VERY LONG REPLY. PLEASE DO NOT CLICK THE BLUE BUTTON TO REPLY. Please use either the 'Reply' box at the bottom of the page to reply, or click the three vertical dots in the top right and chose the top 'Reply' option.
