Voltage drops [in larger layout tracks]
Posted at 09:39:47 Wed 19 Jan 2022
Although a modeller for 50 years or more I have never, until now, been able to build a big layout. Now I have the opprtunity to build a 12' x 12' continuous run layout in 00 - big by my standards. The runs are likely to be in the order of 40 ' using a mix of second hand code 100 track - mostly Hornby and Peco. It wll be analogue control, not dcc, using ancient (but thoroughly checked) Triang and Hornby transformer/controllers to run locos based on Triang/Hornby/Lima/Trix/Wrenn/Reidpath mechs anything up to 70 years old. Can some knowledgeable party tell me whether voltage drop is likely to be a problem over such a distance so that I can plan the wiring loom in advance? Any comments/ suggestions will be warmly welcomed.
Posted at 13:10:15 Thu 20 Jan 2022
Chrissaf has given very sound advice here for bigger layouts. There is nothing worse than seeing trains slow down for what seems no apparent reason. These advice steps would avoid that.
VESPA
Posted 13:10:15 Thu 20 Jan 2022
Posted at 16:45:41 Thu 20 Jan 2022
@ Gordonvale and Vespa Good to know, thankyou.
Posted 16:45:41 Thu 20 Jan 2022
