Glue for loco body
Posted at 10:14:04 Mon 16 Dec 2019
What glue should I use to stick a lug back onto the underside of a loco cab?
Posted at 10:19:46 Mon 16 Dec 2019
Hi David, welcome to the forum. Could you give a few more details?
Hornby, Bachmann, Lima, other?
Plastic, metal?
Shape, weight?
Viewable when in operation?
Perhaps post a couple of photos.
Take care answering. You're only allowed 2 posts 1st time around.
Posted 10:19:46 Mon 16 Dec 2019
Posted at 09:03:28 Fri 20 Dec 2019
Thanks for reply Al.  It's a plastic bodied Hornby 'Evening Star'.  My father had regularly worked the loco at Cardiff Canton so I bought the model for him when he became housebound.  Unfortunately, failing eyesight and arthritic fingers caused the pin linking loco and tender to separate a bit crudely, taking the nut and part of the underside of the plastic body with it.  I did a couple of glue tests out of sight and found superglue worked.  The result seems solid and is invisible from the exterior.  Success!
Posted 09:03:28 Fri 20 Dec 2019
Posted at 09:38:19 Fri 20 Dec 2019
Generally 'Super Glue' will tackle most jobs provided there is adequate surfaces for it to get a hold. Liquid poly is what I would use for most plastic to plastic bodywork repairs.
Posted 09:38:19 Fri 20 Dec 2019
Posted at 10:44:50 Fri 20 Dec 2019
Nice there's a happy ending.
Even more interesting is that your father actually worked the original locomotive - do you have any photos of that?
Posted 10:44:50 Fri 20 Dec 2019
Posted at 11:11:09 Fri 20 Dec 2019
Something I find with superglue is that it leaves a white frosting - is this just the one I use or a general problem?
Posted 11:11:09 Fri 20 Dec 2019
Posted at 11:12:33 Fri 20 Dec 2019
No it is normal.
Posted 11:12:33 Fri 20 Dec 2019
Posted at 11:17:33 Fri 20 Dec 2019
I find that liquid poly often doesn't work with locos, wrong sort of plastic.
Posted 11:17:33 Fri 20 Dec 2019
Posted at 11:54:01 Fri 20 Dec 2019
Yes, I find "Super Glue" seems to work the best. I also found liquid poly doesn't work very well. The biggest issue I found is if you get some of the "Super Glue" on your fingers you have to be careful you do not touch the loco body, as you get a nice glue fingerprint. Unfortunately, "Super Glue" is brilliant at sticking fingers to anything, sometimes better than the thing you want to glue.
Posted 11:54:01 Fri 20 Dec 2019
Posted at 02:27:52 Mon 23 Dec 2019
Laughing I think that we all agree about
This has also been said about in the Thread called "cardboard-models"!!!
My product reviews and layouts can be viewed at: https://www.youtube.com/playlist?list=PLimAq38evXTjOybXJBGr3FGbBLARf8lgk - Also on TikTok @Jimyjames73
Posted 02:27:52 Mon 23 Dec 2019
Posted at 10:21:31 Mon 23 Dec 2019
This could confirm ... the obvious:
In 1942, while searching for materials to make clear plastic gun sights, Coover and his team at Eastman Kodak examined cyanoacrylates, a material that was used during both World Wars (1914-1918; 1939-1945) as an alternative to stitches on large cuts and wounds, rejecting them as too sticky.
Posted 10:21:31 Mon 23 Dec 2019
